OCZ Throttle eSATA stick on ASRock X58SuperComputer
review
Introduction
USB Sticks have replaced the floppy disks of yesteryears as
the medium for file transfers. As file size gets bigger, USB interface seems to
be the bottleneck for such transfers. Manufacturers knew that it and introduced
eSATA ports. eSATA ports if you remember first appeared on ASRock mainboards a
few years ago. It has garner more support these years. We see eSATA ports on
mainboards and even notebooks. eSATA ports comes in two flavours, one is the traditional
eSATA port while the one found on the
ASRock X58SuperComputer is a
powered one. Powered eSATA ports means that the esata device do not
require external power connector to power it up. This mimics the traditional USB
ports, where you just plug the USB sticks and it works. As an alternative to the traditional USB sticks, the OCZ
Throttle’s primary eSATA interface offers an incredible 90MB/second read speeds
and 30MB/sec write speeds, increasing productivity to new heights. The
substantial 16GB stick provides enough storage for your diverse multimedia files
including high-resolution photos, high-definition movies, or large quantities of
music. Additionally, users can access their data via an auxiliary mini USB port
for ultimate flexibility. Specifications eSATA interface (plug directly into any compatible
motherboard or laptop with powered eSATA port)
