Over here you can choose to
apply more voltages to the respective options for better overclockability.
CPU Vcore 0.5v-1.9v
QPI/Vtt 0.8v-1.94v
PCH 0.85v-2.08v
CPU PLL 1.5v-2.58v
DRAM 1.3v-2.6v
DRAM termniation 0.6v-1.305v
Ch A data ref 0.6v-1.275v
Ch B data ref 0.6v-1.275v
Ch A Addr Ref 0.79v-1.05v
Ch B Addr Ref 0.790v-1.05v |
TPM is available on the UD6
which allows you to secure your data with a USB stick as the key. This
option enables this feature. |
