BIOS Screen shots 3 of Gigabyte MA785GPM-UD2H AMD 785G+SB710 Mainboard
Review Bluetooth 20 Jul 2009
BIOS 3
The screen shots are taken with board installed with a AM3 X3 710
processor.
Voltage adjustments can be
made to the corresponding elements in the BIOS.
DDR2 Voltage : default ~ +0.3v
North Bridge Voltage : default +0.3v
South Bridge Voltage : default ~ +0.3v
Sideport Mem Voltage: -0.6v ~ +0.3v
CPU north bridge VID : -0.6v ~ +0.6v
CPU Voltage control :
The integrated graphics can
run in 3 modes. UMA only, Sideport Only or UMA+Sideport which gives the best
performance
UMA Frame buffer size can be
changed here
The Sideport memory timing can
be adjusted here to up to 667MHz.
