CineBench 10 Benchmark of ECS  X58B-A Intel X58+ICH10R Core i7 Mainboard Review
Bluetooth 10 Mar 09
Benchmarks - CineBench 10
CineBench 10 is one of the popular rendering tool that supports newer SSE4 instruction sets. In this test, take a look on how CineBench performs using the Core i7 965 on the ECS X58B-A Mainboard.
It is not difficult to notice that when 1 CPU rendering is involved, the Core i7 series doesn't seem to perform way faster than the QX9770. When it comes to multiprocessing, it is definitely speedier than the QX9770 and Core i7 940. It is 13% faster than Core i7 940 running on Gigabyte GA-EX58-UD5 and 27% faster than Intel QX9770 running at 3.2GHz on Intel P45 chipset mainboard.
As for ECS X58B-A, it seems that running the board at FIX multiplier x 133 does give it a disadvantage with a slightly slower speed in rendering as compared to the ASRock X58SuperComputer. Could it be the BIOS optimisation, or could it be due to the ram timings used are different on the two boards.
Cinebench 10
Rendering 1 CPU
Rendering X CPU
Multiprocessor Speedup
OpenGL
ECS X58B-A
(Core i7 965)
3762 15885 4.22x 6116
ASRock X58SuperComputer (Core i7 965) 3856 15973 4.14x 6798
Gigabyte GA-EX58-UD5 (Core i7 940) 3379 14022 4.15x 6445
ASRock P43DE 3534 12305 3.48x 5981
ASRock P45XE-WiFiN 3534 12565 3.56x 6782
ASRock P45R2000-WiFi 3511 12545 3.53x 6168
ECS P45T-A 3520 12420 3.52x 6000
Gigabyte GA-EP45 Extreme 3519 12374 3.52x 5848
ASRock P43R1600Twins-WiFi with DDR2-1066
3521 12489 3.55x 6118
ASRock X48TurboTwins-WiFi DDR3-1600
3538
12636
3.57x
4113
