In the BIOS Setup
Utility, you can manually overclock the processor. Alternatively, you can
select D.O.C.P or X.M.P. If you choose XMP, you will be provided the XMP
profile 1 and 2 from your XMP compliant memory modules. Just select it and
the system will change the multiplier and BCLK to suit the XMP settings. |
If D.O.C.P is
selected, you can run the system based on tested configuratoins to suit
DDR3-1600 to DDR3-2133 (OC). The BCLK and CPU Multiplier will be set
accordingly to ensure your memory runs at the rated overclocked speed. |
