Futuremark 3DMark06 and 3Dmark Vantage benchmarks of ASUS M4A785TD-V EVO AMD 785G+SB710 Mainboard
Bluetooth 27 Jul 2009
Benchmarks - 3Dmark2006/3DMark Vantage
In this test, we take a look at the integrated GPU's performance when running the Futuremark series of benchmarks.
From the chart below, it can be clearly seen that the 3Dmark06 score jumped from 1797 to 2589, that is a 44% increase when the GPU Clk is increased from 500MHz to 980MHz. When the 4th core is enabled, the score shot up to 2612.
In 3DMark Vantage (Entry), the default test scored E2355 with GPU at 500MHz and sideport at 667MHz (DDR3-1333). When the GPU clock is raised to 980MHz, it shot up to E3704. With the 4th core uncovered, the score went up to 3837.
