BIOS Screen shots 3 of ASRock P55 Deluxe Mainboard
Bluetooth 13 Aug 2009
BIOS 3
The screen shots are taken with board installed with a Intel Core i5 processor.
Vtt voltage can be increased to 2.044v PCH voltage can be up to 1.488v
CPU PLL voltage can be up to 2.324v ASRock Instant Flash allows you to flash the BIOS at BIOS level without the need to prepare a bootable diskette and running the AMI flash utility. Just copy the BIN file to your USB drive, press F6 during POST and it will auto search the attached devices. Just select and flash it in accordingly.
