BIOS Screen shots 1 of ASRock P55 Deluxe
Mainboard Bluetooth 13 Aug 2009
BIOS 1
The screen shots are taken with board installed with a Intel Core
i5 750 processor (2.66GHz).
The is main page showing the
processor & memory information, how the DDR3 running at what speed.
Under CPU EZ OC
Setting, you can pick the pre configured settings of up to 4.2GHz for this
processor. Do take note that these settings changes the voltage levels
applied to the CPU for overclocking it to higher speeds. IES can be enabled
and Good Night LED can be enabled too.
BCLK can be set
from 133-200MHz, PCI Freq can be set from 100-150MHz. CPU Ratio can be
increase to 20x and turbo is 21x
You can select the
QPI Freq. Auto, 7.2 or 6.4 can be selected.
The same applies
for EZ OC setting for Memory. You can select the DDR3 setting. This also
correspond a change in the BCLK. For example if DDR3-2000 is selected, the
BCLK will be set to 200MHz. You will need to lower the CPU multiplier and
adjust different voltage levels to make it run smoothly. It is actually
overclocking.
You can choose to
customise the ram timings or just let it automatically select the XMP
values.
For DRAM Dreq, you
can choose to run it in ASync mode of DDR3-1200 or DDR3-1600 (in this case
for the core i5 750 processor)
