BIOS Screen shots 2 of ASRock M3A790GXH/128M AMD 790GX+SB750 Mainboard
Bluetooth 18 May 2008
BIOS 2
The screen shots are taken with board installed with a AM3 X3 710
processor + ASUS Radeon HD 4870X2 EN TOP
The memory clk running in
async to the CPU CLK |
Memory timings available for
adjustments |
If you use the integrated
graphics, you can choose to use UMA, SIDEPORT or UMA+SIDEPORT to boost the
iGPU performance |
The onboard GPU can also be
overclcoked from it's default of 700MHz to 1GHz. |
HT Bus Speed is selectable
from 200MHz to 2GHz. You can lower this to ensure a better overclock. |
