BIOS Screen shots 1 of ASRock
M3A785GXH/128M AMD 785G+SB710 Mainboard
Review Bluetooth 13 Aug 2009
BIOS 1
The screen shots are taken with board installed with a AM3 Phenom
II X3 710
processor.
The is main page showing the
processor & memory information, how mcuh memory is shared etc.
Under OC Tweaker, the first
option allows you to load factory settings for tested oveclock by up to 50%
of it's default speed.
For the integrated graphics
core, the selections available range from 700MHz to 100MHz. You can of
course set your own frequency that works. The ASRock M3A785GMH/128M only
allows up to 900MHz in this pull down menu.
CPU Freq range from 150-
500MHz,
PCIe Freq range from 75MHz to
250MHz
There is ACC which when
enabled opens up the hidden cores of your Phenom II X3 or X2 processors
