BIOS Screen shots 4 of ASRock
M3A785GMH/128M AMD 785G+SB710 Mainboard
Review
Bluetooth 6 Aug 2009
BIOS 4
The screen shots are taken with board installed with a AM3 X3 710
processor.
Sideport voltage can be upped
to 1.8v at the max. |
If you have different
settings, e.g. oc settings, ram settings etc, you can save them in 3
different profiles. Just load them accordingly for testing or gaming. |
ASrock Instant Flash allows
you to flash the BIOS without the need to boot into Windows. Just download
the BIOS file, copy it into an external eSATA drive or a FAT32 formatted HDD,
it will auto scan for the file and you can choose which version to flash. |
You can choose to run the
board with UMA, Sideport or UMA+Sideport mode. UMA+SIDEPORT will give you
the best 3D performance |
The shared memory with on
board RAM, default is 256MB |
