Gigabyte GA-X48T-DQ6 Intel X48 chipset mainboard review - SiSoft Sandra XII
Bluetooth 2 Jan 2008
Benchmarks
The GA-X48T-DQ6 and GA-P35T-DQ6 are put to the test using SiSoft Sandra XII.
From the chart, we tested the Arithmetic and multimedia performance of the CPU. The CPU used is a QX9770 which clocks at 3.2GHz (400 x 8).
The board X48T-DQ6 is paired tested twice, paired with a 8600GTS and later a 8800GT.
Sandra XII Gigabyte X48T-DQ6 with 8600GTS Gigabyte X48T-DQ6 with 8800GT Gigabyte P35T-DQ6 with 8600GTS
Memory Bandwidth 7150/7129 7147/7138 7458/7463
Arithmetic - Drystone ALU 59784 59428 59842
Artithmetic - Whetstone iSSE3 47251 46750 47277
Multimedia - Int x8 iSSE3 352332 352414 352534
Multimedia - Float x4 iSSE2 192857 193116 193241
We can see from the chart below that the results aren't that far off. In fact, we noticed something interesting. The P35T-DQ6 with the latest BIOS seems to perform slightly better. Looks like the F3C BIOS on the X48T-DQ6 isn't well optimised yet.
