Review Introduction to ECS N9600GT-512MX-P
graphics card with Accelero S2 passive cooler
Bluetooth 21 Feb 2008
Introduction
Today, NVIDIA launches
it's new GPU, the 9600GT. This new GPU brings performance to another level with
it's new GPU Core. While most of you will be seeing a lot of reviews based on
reference cards, we bring you the first review with a custom ECS design, with a
Accelero S2 passive cooler.
The ECS N9600GT-512MX-P is
the first NVIDIA 9600GT card that comes paired with the Accelero
S2 passive cooler. Based on the G94 GPU core, this card spots a 512MB
GDDR3, 64 Shader processors and has a
Memory interface is at 256 bits. Reference designs are clocked
650/900/1625 for GPU Core/Mem/Shader clk. The ECS N9600GT-512MX-P is factory
clocked at a higher 680/925/1728. That will give it a boost in
performance.
The ECS N9600GT-512MX-P is also one of it's kind. It comes
with the Accelero S2 passive cooler. With this cooler, ECS is able to provide a
quiet 0dB solution. The passive cooler also helps to cool down the GPU
substantially without even exceeding 70 deg celsius under heavy load.
The package comes with a component cable, 1 DVI-DSUB and 1 DVI-HDMI converter, CDROM
and user manual. No game is
bundled with the package. A audio cable is provided for hooking up your
onboard audio to be channelled to DVI->HDMI out
