BIOS Screen shots 1 of ECS A780GM-A AMD 780G+SB700 mainboard
Bluetooth 13 Apr 2008
BIOS 1
The DRAM Frequency can be set to operate in ASync mode of 200,266,333,400 or 533 MHz. Lower this value to restrict the RAM freq to run at a ratio of the CPU CLK durig overclocking
CAS Latency and RAM timing adjustmenets, CAS, tRCD, tRP, tRTP, tRAS etc. cmd rate 1T/2T option is not available Other options are Gang/Ungang mode for Phenom processors. HDMI Audio enable/disable option is found here (should be group under other settings)
In this page, you see a few options. First is the CPU voltage, DIMM voltage adjustments. CPU overclock func (CPU Frequncy adjustments) and GFX engine clk Override (which is GPU clk adjustments). Over here CPU voltage can be offset by up to +252mV in addition to the default voltage set udner AMD CPU FUNCTION
DIMM voltage can be increased over here by up to +630mV. In actual fact, the window allows us to set to a maximum of only 60.
