3Dmark05 and 3Dmark06 benchmarks of ASRock Penryn1600SLI-110dB NVIDIA 650i chipset mainboard review
Bluetooth 5 Mar 2008
Paired with a Vvikoo 9600GT Turbo on board using QX9770, the mainboard is tested for it's performance in 3DMark06 and 3DMark06.
The same card is paired with a ECS 9600GT with Accelero S2 we reviewed before to test for SLI performance.
As we can see form the chart below, the Gigabyte P35T-DQ6 performs slightly better with the same graphics card, scoring 19009 while the ASRock Penryn1600SLI-110dB scored only 18881.
As the NF650i support SLI in a DUal 8x configuration, we put it to the test. With SLI enabled, the score shot up to 20351.
In 3Dmark06, the ASRock Penryn1600SLI-110dB does better with a score of 11934 as opposed to 11914 on the Gigabyte P35T-DQ6. With SLI enabled using two cards clocked at 700/1000(GPU/MEM), it scored 15781.
