ASRock
4Core1600P35-WIFI+
Intel P35 ICH9R chipset mainboard review - BIOS Screen shots Bluetooth 7 Jan 2008
BIOS 2 (Updated with BIOS P1.00)
QX9770.
The screen shows that the
Intel QX9770 processor is detected.
In overclock mode, you can set
it to manual, auto or I.O.T mode. I.O.T mode allows you to select a
percentage increase in CPU and PCIe clock of up to 30% each.
A Max of 30% can be selected
for both CPU and PCIe Freq clk. Alternatively you can set it to manual
settings.
CPU Freq range is 100 ~ 800 MHz.
PCIe freq range is 50 ~ 150MHz.
With my Samsung DDR3-1066
modules, I can select to operate in ASync memory settings of 533MHz or
667MHz. CPU QX9770 operates at 8x400MHz.
