ASRock 4Core1600P35-WIFI+ Intel P35/ICH9R chipset mainboard review  - SiSoft Sandra XII
Bluetooth 9 Jan 2008
Benchmarks
The ASRock 4Core1600P35-WIFI+, Gigabyte GA-X48T-DQ6 and GA-P35T-DQ6 are put to the test using SiSoft Sandra XII.
From the chart, we tested the Arithmetic and multimedia performance of the CPU. The CPU used is a QX9770 which clocks at 3.2GHz (400 x 8). One thing to note is that with P1.00 bios, the RAM timing is fixed at CAS 6, 7-7-20, setting the CAS latency to other settings result in no BOOT. Looks like it is a BIOS bug in p1.00
Sandra XII Gigabyte X48T-DQ6 with 8600GTS Gigabyte X48T-DQ6 with 8800GT Gigabyte P35T-DQ6 with 8600GTS ASRock 4Core1600P35-WIFI+ with 8800GT
Memory Bandwidth 7150/7129 7147/7138 7458/7463 7294/7306
Arithmetic - Drystone ALU 59784 59481 59842 59502
Arithmetic - Whetstone iSSE3 47251 46750 47277 46337
Multimedia - Int x8 iSSE3 352332 352414 352534 351580
Multimedia - Float x4 iSSE2 192857 193116 193241 192672
Comparing the two boards the Gigabyte GA-X48T-DQ6 and ASRock 4Core1600P35-WIFI+ both paired with a ECS 8800GT Graphics card, we noticed that the differences is very insignificant.
