BIOS Screen shots 2 of J&W RS780UVD-AM2+ AMD 780G+SB700 mainboard
Bluetooth 29 Jan 2008
BIOS 2
The screen shots are taken with board installed with a Intel QX9770.
CPU multiplier can be upped to x25. It is best used with Black edition AM2 CPUs like 5000+ or 6400+ CPU-NB HT Link speed. AM2 default is 5x. Phenom 9600 will run at X9 (1800MHz)
Dimm voltage can be set, up to +0.35v, that gives you a maximum of 2.15v CPU voltage control allows you to boost the CPU voltage. A Max of 1.45v can be applied
NB voltage can be upped to 0.24v. This is an important setting if you wish to increase the GPU CLK SB voltage can be upped by +0.03v
