Jetway M28GT3-PHG
GeForce 7050-630A mainboard review
With HDMI connector, one can easily set up this board for as a HTPC by hooking it up with the XBOX360 HD DVD drive (HDCP supported on board). The onboard 1 x GbE LAN port, also makes it easy for you to transfer large multimedia clips for playback via this mainboard. The regret is that S/PDIF is missing. The package seems to leave out the brackets for LPT and TV-out. Jetway could have thrown in a HDMI->DVI converter so that users can still get quality image from display out. The manual is too simple, with no directions on how to configure the HDMI etc. Overclocking options a plenty for a mATX board. We were able to POST to 295MHz. Stable at 285x10. The CPU just wouldn't want to go beyond the 300Mark even with a low multiplier is used. Overall, the board has good performance and a nice BIOS. The cons would be the package and chipset being too hot. Perhaps an active cooling would be a better choice.
Pricing (US/UK)
