Gigabyte GA-X38-DQ6 Mainboard Review - Lost Planet
Bluetooth 23 Sep 2007
Gigabyte P35-DQ6
Benchmarks - Lost Planet
In the game benchmark Lost Planet, we test run the two boards with HD 2600XT at 1280x720 and reached the final scores of snow 20, cave 22 for both boards. When we enable CrossFire, the Gigabyte P35T-DQ6 is able to tap the power and fps improved by almost 100%. The same cannot be said of the GA-X38-DQ6. Is it a driver issue or could it be something else ?
We re-tested the same board over again with the drivers reloaded and the GA-X38-DQ6 just scores the same whether CrossFire is enabled or not.
