Gigabyte
GA-MA790FX-DQ6
(AMD 790FX) mainboard review - BIOS Screen shots
Bluetooth 16 Nov 2007
BIOS 2 (Updated with BIOS F2j)
The screen shots are taken with board installed with a Phenom
GP-9600 processor. If you are using a AM2 processor, some of the options might
not be visible.
CPU Frequency can be set from
200 ~ 500MHz. There is no CPU ratio/multiplier option available in this
BIOS. |
HT link frequency can be set
to beyond 1GHz, up to 2.6GHz or 13x |
PCIe CLK can be set to 200MHz |
ASync Memory clk can be se to
1066 MHz |
Over here, you can set the
individual parameters related to the DRAM including command rate, trfc, cas
latency etc. |
In PCIe configuration, there
is this option which enables the speed mode of PCIe gen 2 slot. It can be
set to auto, disabled, SW and HW switch. |
