3Dmark05 and
3Dmark06 benchmark of AMD Phenom GP-9600 on Gigabyte GA-MA790FX-DQ6 Benchmarks - 3Dmark2005/3DMark2006
Paired with a ASUS EAH2600XT, the graphics performance test is performed. Apparently, the difference between the difference is noticeable. Gigabyte MA790FX-DQ6 based on the 790FX chipset leads the 770 chipset. In comparison to the Intel Quad Core clocked at 2.3GHz, the two boards are not a match, lagging behind by around 200 points. Just to add, when operating the Gigabyte MA790FX-DQ6 in CrossFire mode with 2 identical 2600XT, it scored 12948 mark. That is a 37% boost in graphics performance.
In 3Dmark06, the results shows a difference of around 90 points when we compare both platforms. There is little performance difference between the 790FX and 770 chipset. We can see that the CPU/HDR/SM2 scores of QX6700 clock at 2.3GHz is generally higher. This resulted in a high final score.
In CrossFire mode, it scored 8529 mark with a SM2 score of 3110, SM3/HDR of 3835 and CPU score of 3103. CrossFire gave it an almost 100% boost in 3Dmark06.
