ECS G33T-M2 mATX Intel G33/ICH9 Mainboard Review Intro 4/4
Bluetooth 28 Sep 2007
ECS G33T-M2
BIOS Screen shot 1 (BIOS 0402 beta)
Something different in the BIOS design of ECS G33T-M2 is taht the CPU ref frequency is in a percentage of the default CLK. For example, at 650MHz, it is 244% of the default 266MHz of the X6800 processor. Basically, by changing the Ref Frequency, you will see the corresponding CPU Freq. The Clk gen is able to support up to 650MHz.
The Memory voltage can be max up to 2.0v which is a bit not enough for the DIY. Anyway, this board is meant for normal desktop user.
CPU Multiplier can be adjusted Over here you can set the share memory size for the integrated video
The screen where you can overide the SPD values of your DIMM and specify it to run at higher or lower latency ASync DDR setting allow you to configure to run your DRAM frequency at either DDR2-667 or DDR2-800
