BIOS Screen shots of ECS A770M-A AMD 770 chipset mainboard Review Bluetooth 26 Nov 2007
Chipsets on board
CAS Latency can be changed but the underlying ram parameters are auto detected.
CPU Frequency can be set up to 500MHz, but CPU multiplier is missing even though we are using a X2 5000+ processor.
CPU Voltage can be upped by 300mV of default
DIMM Voltage can be upped by 630mV of default 1.8v
Memclk can be set to 5 different values. Setting it to 533MHz resulted in no POST.
