Introduction of DFI LP UT
790FX-M2R AMD 790FX chipset mainboard Review
Bluetooth 26 Nov 2007
Introduction
DFI
has been quiet for sometime as it was a bit late to market it's Intel series of
boards. Anyway, for the AM2+, DFI is quick to respond with their top tier
Lanparty series, the 790FX-M2R.
The platform entirely supports AMD's Quad-core processor, Phenom (FX) series.
790FX provides the latest version of Hyper Transport 3.0 for accelerating the
CPU; LP UT 790FX-M2R features the highest performance chipset 790FX and SB600 as
the NB and SB. In addition, DFI brings you an ultra-performance OC platform with
the utmost features such like Digital PWM, Bernstein Audio module and advance
heat pipe + Transpiper.
DFI 790FX can support a total of 3 CrossFire VGA cards at the same system
anytime. LANParty UT 790FX-M2R provides a brand new FSB technology, the Hyper
Trsansport3.0, which maximizes the bandwidth up to 41.6GB/s. This is a very
significant functionality while CrossFire is at working. It needs a wider and
faster bandwidth to accelerate the data transportation.
On board is a 7-phase PWM, which contains 6-phase for processor and a
particularly 1-phase for Northbridge. The extra 1-phase PWM is an independent
electricity power to support Northbridge. That makes the overclocking ability
more flexible in voltage options.
DFI LP UT 790FX-M2R has equipped the powerful weapon ”Transpiper” too; a heat
pipe sub- assembly, an extended design from Southbridge, Northbridge and now to
PWM. The design of it is unique to any others in market. The, Transpiper serves
as an extension joint to carry the heat out from the chassis. The Transpiper can
be extended to the outside of the PSU fan.
The package
Transpiper serves
