ASUS M2A-VM HDMI (AMD 690G) mainboard review Mainboard BIOS options 2
Bluetooth 21 Mar 2007
ATI RD480 Boards
BIOS 2
HDMI support must be enabled if you connect the bracket, otherwise you won't see any image on your HDTV
ASYnc memory clk ratio can be set to run the memory in sync or async to the CPU clk. LDT Frequency or commonly known as the HT multiplier. Can be set from the options above. For overclocking HTT > 250, it is advisable to set it to 800 (4x) or below.
UMA Frame Buffer size can be set to 256MB Without the need of an OS, you can flash update the BIOS by running this tool in the BIOS.
