ASUS M2A-VM HDMI (AMD
690G) mainboard review Introduction
Bluetooth 5 Feb 2007
Introduction
ASUS
M2A-VM HDMI is the board that a lot of HTPC users will look forward to. Today,
we got hold of more information of the upcoming board from ASUStek.
ASUS M2A-VM is a mATX baord with the
integrated AMD 690G formerly ATi RS690 chipset paired with SB600 south bridge.
The board supports Athlon64/X2/Sempron and it AMD Live! Ready. It supports aDual
channel memory architecture with 4 x 240-pin DIMM, support max. 8GB DDR2
800/667/533 ECC and Non-ECC,un-buffered memory is supported.
For video, the integrated ATI
Radeon X1250-based graphics can share up 128MB of memory and supports Dual VGA
using DVI-D with max. resolution 2560x1600 (@ 60Hz) and RGB with
max. resolution 2048 x 1536 (@85Hz). An external PCIe based daughter board can
be slotted with slots for HDMI interface with HDCP.
The board also supports ALC883 High Definition Audio 6-channel CODEC and GbE,
10 USB ports, 4 SATA II with RAID 0,1,5,10. Other features include SFS (Stepless
Frequency Selection) from 200MHz to 400MHz at 1MHz increment, Adjustable CPU
Voltage at 0.0125V increment and ASUS C.P.R.(CPU Parameter Recall)
Specifications |
CPU
Support AMD® Socket AM2 Athlon64 / Athlon64 FX /
Athlon64 X2 / Sempron
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
AMD Live!™ Ready
Chipset
AMD 690G
ATI SB600
Front Side Bus
2000 / 1600 MT/s
Memory
Dual channel memory architecture
4 x 240-pin DIMM, support max. 8GB DDR2 800/667/533 ECC and
VGA
Integrated ATI Radeon X1250-based graphics
Maximum shared memory of 256 MB
Supports DVI-D with max. resolution 2560x1600 (@ 60Hz)
Supports RGB with max. resolution 2048 x 1536 (@85Hz)
Dual VGA output support:
RGB & DVI
Note: DVI-D can not be converted to output RGB Signal to CRT.
Expansion Slots
1 x PCI Express x16
1 x PCI Express x1
2 x PCI
Storage
1 x UltraDMA 133/100
4 x Serial ATA 3Gb/s supporting RAID 0, RAID 1,RAID10
LAN
PCIe Gb LAN
Audio
Supports Jack-Sensing, Enumeration, and Jack-Retasking
Supports S/PDIF out interface
Overclocking Features
SFS (Stepless Frequency Selection) from 200MHz to
Adjustable CPU Voltage at 0.0125V increment
USB
10 USB2.0/1.1 ports
Special Features
ASUS MyLogo2
ASUS CrashFreeBIOS3
ASUS EZ Flash2
ASUS Q-Fan
ASUS O.C Profile
ASUS Music Alarm
Back Panel I/O Ports
1 x Parallel
1 x PS/2 Mouse
1 x PS/2 Keyboard
1 x DVI
1 x VGA
1 x RJ45
4 x USB 2.0/1.1
6-channel Audio I/O
Internal I/O Connectors
3 x USB 2.0 connector supports additional 6 USB 2.0
ports
High Definition Front panel audio connector
COM port connector
CD audio-in connector
1 x S/PDIF output connector
CPU / Chassis/ Power Fan connectors
Chassis Intrusion connector
24-pin EATX power connector
4-pin ATX 12V Power connector
BIOS
8Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, SMBIOS
2.3
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PXE, WOR by
PME
Support CD
Drivers
ASUS PC Probe II
ASUS LiveUpdate Utility
Anti -virus software(OEM version)
Accessories
User' s manual
1 x Serial ATA cable
1 x SATA power cable
1 x UltraDMA 133/100/66 cable
1 x FDD cable
1 x I/O Shield
Form Factor
uATX Form Factor, 9.6" x 9.0" (24.5cm x 22.9cm)
