ASUS M2A-VM HDMI (AMD
690G) mainboard review - Connect to HDTV
of
Connection to HDTV using the HDMI interface
Once that is done, power up the system with your existing display and go into the BIOS. Remember to enable HDMI support in the BIOS option. Also, set HDMI Audio to Enabled so that the audio will be channeled out to the HDMI port.
Once it is done, you can now boot up the PC and use the LCD TV as your screen. In our tests, we are able to use the HDTV as a display unit for our programs. Get facinated running 3DMark06 on a 42" Screen !! Screen captures are shown on the next few pages.
