ASRock
ConRoe1333-DVI/H HDCP Mainboard Review Intro 2/4
Gallery
At the bottom left corner you will see the 4 SATA II connectors controlled by the ICH7 south bridge. Just above it are external connectors for USB brackets. On the right are 4 DDR2 DIMM slots supporrting up to 4 pc of DDRII667. On the back panel, you will find the PS/2 Keyboard and Mouse, LPT1 port, VGA out, 4 USB, GbE and 7.1 ch audio ports. Notice that the BIOS is located at the right hand corner of the mainboard. The DVI Graphics-HDCP add on card provided Free in the package. This card uses the SiliconImage chipset to support DVI-HDCP. This card is to be plugged into the PCIe slot of the mainboard.
