ASRock
ConRoe1333-D667 945GC A2 Mainboard Review
- System Clock and Sandra 2007
Benchmarks
In the following tests, other than the Jetway 965GDAG which is a G965 chipset mainboard running at DDR2-800, the 4 other boards are configured to run at CAS 3, 3-3-8, 1T SYNC DDR2-533 using a X6800 processor. The three boards are based on different chipsets. Although Intel has specified i975x and i965p official supports the Core2 Duo processor, the older chipsets like the 945P/G and VIA PT880Pro are used on the ASRock boards. Below are the benchmarks done on the Sandra XI memory benchmark. We chose to run it at DDR2-533 is because the memory is running at 1:1 ratio, that is to say in SYNC with the CPU. Although one might get a slightly higher score in this benchmark if you choose to run in ASync mode say DDR2-667, there isn't much difference in the performance, in fact, it might get a bit slower in some benchmarks. The performance of this board in this test is quite similar to that of the ConRoe1333-DVI/H. Will it give you better results as it uses a newer stepping of the chipset. Let's read on. Next >>>
