Catalyst 7.10 Performance
Analysis
Benchmarks
We just installed catalyst 7.10 and did some simple tests. We noticed the
performance of 7.10 is better than 7.9
In addition, Catalyst 7.10 allows you to run CrossFire without the need to hook up the CrossFire interconnect bridge. It is known as Software CrossFire. We wil investigate the performance of CrossFire without installing the bridge. So, will there be any performance difference in other benchmarks? Let's read on. Test System Environment Intel X38
Graphics - 3DMark2005 (1024x768x32)
