Gigabyte has
definitely put in effort in putting the best in the package. The package
consists of the unit itself, a 840mAH battery pack, a leather case, hand strap,
stereo ear piece. It also comes with a 256 mini SD (comes with PaPaGo G10), data
cable, and software. There is also a thicker 1300mAH and a traveller charger.
Generally,
the phone has good voice clarity. In fact it is the same as the O2 Atom. I also
tested the FM tuner and TV function. FM radio is definitely a plus for this
unit. Unfortunately, the TV is a normal RF NTSC TV. As the tv system here is PAL
only, I am unable to get another reception of local broadcasts. The WiFi
connection seems a bit slower than my Atom, well it could be due to the
processor which runs slightly slower at 416MHz using the Intel PXA272. Skype
would be a good add on to the PDA for some free calls. As for GPS, the papago
v10 is only with Taiwan map, you can use Mapking v7 if you wish.
The PDA
comes with a 2.1mpixel cmos camera. Photo quality is so-so and I think it is
best in daylight. In terms of expandability, it is best to use a high speed SD
card. WAV and MP3 can all be assigned as ringtones and SMS indicators.
In terms of
battery life, the thicker battery rated 1300mAH should last longer. One would
probably use the 840mAH as a back up battery instead.
In
conclusion, it is a remarkable PDA phone for the start. It would be nice if
Gigabyte will include a DVB-H and WCDMA versions of the phone. Gigabyte has show
that it has the capability of being a strong contender against Dopod and O2.
Pros :
- MS mobile 5
- JAVA, MMS, GPRS, EMS,
Bluetooth
- Memory expansion using
SD
Radio, NTSC TV
Cons :
- Photo image quality
- Steep price
Here are my ratings out of 10
stars.
Category |
Score |
SMS / Keyboard Response |
8
/ 10 |
Features |
10
/ 10 |
Ease Of use |
8
/ 10 |
Documentation |
8 / 10 |
Overall Rating : |
8.5
/ 10 |
