Gigabyte
GV-NX88X768H-RH (GeForce 8800GTX)
Review Benchmarks - Conclusion
Conclusion Gigabyte's GV-NX88X768H-RH is the fastest card of all series so far. Not only does it perform better, it also has better image quality. As we can see from the benchmarks, the results are quite similar to the refernce card we presented before. It is all within less than 1% of difference which is attributed to a different driver used perhaps. The image quality of this card has improved from previous generations. In our HQV test, it scored a high of 118 out of 130 points. This is not unusual as previous cards were unable to do well in tests like Film Cadence and Noise Reduction. Playing back of H.264 movies or transport streams is smoother than before as the GPU offloads the CPU in delivering the HD contents through PureVideo using PowerDVD. In fact CPU utilisation was about close to 100% when hardware acceleration is not enabled. With acceleration enabled, CPU utilisation drops to close to 40-50% depending on TS. The packaging and bundle is quite the same from most of the Gigabyte cards. It comes with the cables, games and a tv output box. Perhaps throwing in a pair of headphones might be good for gamers who buys this expensive card? When we received the card, we prepared a high powered PSU. At the end of the day, we used the 3 yrs old old ANTEC true power 480W PSU to power it up. It works fine for a single card. Noise level is acceptable but the length of the card seems to be longer than any current video cards. In fact, the length exceeds the width of my Gigabyte GA-945P-DQ6. It also takes up the space of 2 slots. Overall, I am very impressed with the quality both in 3D and 2D. At this moment, the GeForce 8800GTX should remain as the speediest card we have ever tested. Price ~ 599 USD. Pros
