GIGABYTE GA-K8N51PVMT-9 (GF6150) Intro 4/5
Bluetooth 1 JAN 2006
BIOS I
CLK can be set from 200 ~ 300MHz. PCIe Clk can be fix from 100~145MHz. Ram adjustments are available after CTRL+F1 is pressed. Over here, the CAS Latency, Trp, Trcd, Tras can be set. 1T/2T cmd can be set too.
Maxmemclk to run the ram in ASync mode to the CPU CLK This should be set lower in order for the HT to be under 1GHz when overclocking.
