GIGABYTE GA-K8N51PVMT-9 (GF6150) Intro 1/5
GIGABYTE GA-K8N51PVMT-9 GA-K8N51PVMT-9 is the mATX solution based on GF6150 integrated chipset. Small in form factor, this board take aims on potential HTPC builders that wants video output direct to TV. This mainboard uses the Nvidia GF6150 chipset, the Northbridge: nVidia GeForce 6150 and Southbridge: nVidia nForce 430 MCP. (There are various combinations of NB_SB pairs, a comparison of them and supported features can be found here). This Socket 939 board supports up to 4GB DDR400 memory in dual channel mode and the Socket 939 processors including the AMD Athlon 64/FX/X2. It is capable of HT of 1GHz and AMD Cool 'n' Quiet Technology. It supports an external PCie x16 graphics card and comes built in with a PureVide-CE quality video processor to acclerate WMVHD video playback. There are also 2 ATA/133 + 4 ports of Serial ATA II 3.0Gb/s, RAID 0, 1, 0+1, 5s. Audio wise, it has 7.1 Realtek ALC880 HD audio codec. There is a GbE controller using a Simply PHY. The board also uses VIA 6307A 1394 controller. It also can support up to 8 USB 2.0 ports, 4 in rear I/O and 4 more via headers on board using brackets. The package also comes with a TV-OUT box for direct connection to a TV set equipped with component video. The box is connected via Svideo port at the back panel of the board. Specifications Processor
Chipset
Memory
Internal I/O Connectors
Expansion Slots
Rear Panel I/O
Power
Form Factor
H/W Monitoring
BIOS
Other Features
