Gigabyte
GA-965P-DQ6 REV 2 (i965P) Core 2 Duo Mainboard Pricing
of
Gallery Gigabyte 965P-DQ6 Rev 2.0 Looking at the board, there are some noticable changes. Firstly, the coils used near the DIMM slots are now changed into the black square blocked caps. The orientation of the IDE channel is also cahnged. Behind the South bridge, you will find a heatsink. This is not found on the original version of the mainboard.
The caps near the Audio codec is also changed.
