Gigabyte 3D Rocket II GH-PCU23-VE Review 4/5
of
Conclusion From the results, we can see that the Gigabyte 3D
Rocket II GH-PCU23-VE is definitely a very low noise yet high performance
heatsink/fan that works on all platforms. With its duct design inherited from
Rocket I, it also helps to cool down the MOSFETs surrounding the CPU. With a Dimension 112 x 112 x 160 mm and a fan
Dimension 92 x 92 x 25 mm, it is a big in size and weighs 640g. I would have
expected a slimmer heatsink and probably shorter. Nevertheless, the 4 heatpipes
and aluminium fin material helps to dissipiate the heat from the top and bottom
of the heatsink. With its newer design, the fan speed of Fan Speed 1,500 ~ 3,000
RPM gives only noise of Noise 16 ~ 33.5 dBA. The univeral retention unit and the clips provided
also makes it one of the heatsinks that is compatible with all platforms. Thus,
you no longer need to change heatsink if you decided to change platform in the
months to come. Finally, I would say the heatsinks' Blue LEDs stands out and the UV rings
will also help to make your BOX looks very different. Discuss Pros Cons Ratings Here are my ratings out of 10. Category Score 10 / 10 8 /
10 10
/ 10 - 8 / 10 9
/ 10 9
/ 10 Related Reviews 1
