EPoX EP-9U1697GLI-J (ULi M1697) Benchmarks 2/8
Bluetooth 30 Jan 2006
Benchmarks
In this test, we measured the CLK used by the two boards. The Jetway NF4 SLI board runs at a slightly tuned up clk speed of 200.9MHz. The EPoX EP-9U1697-J runs at 200.4MHz.
As this board supports compatible SLI, we configured it to work in SLI mode with Forceware 81.98 with no problems at all.
The following readings are obtained using CPU-Z.
The following are the memory benchmarks of the two boards in two different configurations. They're taken at CAS 2, 5-2-2, 1T cmd.
