ECS PX1 Extreme (i965P) Review Intro 4/5
Bluetooth 17 Oct 2006
 Pricing from
various
vendors
Chipsets
Memory timings can be set to run in SYNC or ASync. In this case, we use SPD which is CAS 5, 5-5-18, DDR2-800. To run in Sync or for o/c purposes, setting it to 533MHz is the best.
RAM timing adjustments can be adjusted here. THey include CAS Latency, tRAS, tRP, tRCD.
CPU Multiplier can be set from 6x-11x. Only available on Engineering Sample CPU DIMM voltage can be set to +0.35 of default.
