ECS NFORCE 570 SLIT-A NF 570 SLI Intel Edition Conroe Mainboard Review Intro 4/5
Bluetooth 29 Aug 2006
ECS NFORCE
BIOS Screen shot
PCIe Frequency should be fixed to 100MHz. In the BIOS, there are options for you to o/c your PCIe bus.
In the DRAM timings, we see some interesting options. There is a MEM Turbo Mode. Under configuration, you can set the usual ram timings including DRAM command rate to 1T. If you intend to use 1T, make sure your DIMM voltage is raised to ~2.0v or more.
CPU Multiplier can be set from 6 x - 11 x for the X6800 ES
FSB and MEM Turbo mode increases the frequency of the settings. It can be enabled for better performance.
SFSB Speed can be set to set from 800MHz to 1300MHz. For our X6800. 1066=> 266MHz MHz FSB. From the option, it means that the FSB window is from
800~1300 => 200MHz ~ 325MHz.
