ECS KA3 MVP Extreme AM2 board (ATi Xpress 3200) Review Intro 1/5
ECS KA3 MVP Extreme AM2 board (ATi Xpress 3200) If you have been following our AM2 reviews so far, most of the reviews are based on Nf570 or 590 SLI chispet. Today, we take a look at ECS KA3 MVP, a serious contender for the performance market. The ECS KA3 MVP is based on the ATi RD580+SB600 chipsets. With its integrated circuitry to support Dual PCIex16 slots which we discussed sometime ago (Read the article on ATi RD580). This chipset definitely is a serious challenger to the NF500 series especially the highest end 590 SLI chipset. With the availability of SB600, ATi customers do not need to rely on NV (which bought ULI) for the ULI 1575 south bridge to be paired with the North ATi RD580. This will definitely speed up development of the ATi platforms pairing its own chipsets together for utmost performance. The KA3 MVP supports the Socket AM2 Platform ATI Crossfire™ Xpress 3200 chipset that is the first unrestricted 2x16 PCI Express soluction.The board supports DDR2-800 and 6 ports of SATA II with RAID by SB600 and Jmicron controller on board. KA3 MVP also has GbE + Fast Ethernet supported out of the box. To add on, it has support for 1394 support and 8 ch HD audio. With its scalable D.G.E PCI Express slots (Dual 16x slots), you can now run CrossFire on it for improved graphics performance or can use it for quad-display. The board also supports I.O.C, a dynamic overclocking technology which detects system load and instantly boosts frequency for overall performance. The board also supports eSATA allowing you to hook external SATA enclosures to the mainboard for data backup purposes. Top hat flash is supported. Just in case you misflash your BIOS, just fit the top hat flash on top of the existing BIOS and boot up. Remove the top hat flash and flash the correct BIOS to the onboard BIOS chip and you have recovered your dead BIOS.
