ASUS M2N32-SLI Deluxe Wireless Edition AM2 Review Benchmarks 2/9
Bluetooth 23 May 2006
Benchmarks
In this test, we measured the CLK used by the boards. Both the ASrock boards are run at CAS 5, 5-5-10, 2T 8 beats while the ASUS is run at 1T cmd 8 beats. The boards default clock spans from 200 ~ 202 with ASUS M2N32-SLI running at 200.9MHz.
With that in mind, we take a look at the memory benchmark scores using Sandra 2007. In contrast to the earlier chipsets for the Socket 939, it seems that the new chipset 590SLI has something "special". It was able to boost the memory performance by almost 1000 points ahead of the older Socket 939 chipsets. Is there some form of optimisation ? Will it impact the performance of games? We will check that out later.
