ASrock AM2XLI-eSATA2 (ULi M1697) Intro 1/5
Bluetooth 27 June 2006
ASrock
AM2XLI-eSATA2
Do you still remember the 939SLI-eSATA2,
939SLI32-eSATA2 and K8SLI-eSATA2 boards ? I suppose you do. These excellent
boards provide the capability of eSATA and SLI compatible functions on their
boards for the K8 platform.
With the launch of the AM2 CPUs, it is
not surprised that ASRock releases yet another board based on the ULI 1697
chipset. This board known as the AM2XLI-eSATA2 (see the X instead of S),
is the variant of the popular 939SLI-eSATA2 board. This mainboard supports
the ASRock's XLI technology and
eSATA2 support.
This board comes with 2 PCIex16 slots which can be configured to
work in a single PCIe x16 mode or Dual PCIe x8. This allows XLI operation by
pairing up two similar GeForce 6600, 6800 or 7800 cards and run it in tandem to
improve graphics performance. (XLI technology is basically a technique to speed
up the GPUs with two similar NV cards using the PowerExpress Engine (driver), do
take note that anything beyond 81.98 onwards disabled this feature). You could
also get ready for ATi's Physics solution which should be able to work with 2
PCIe slots (irregardless of desktop chipset) to run say a X1900XT and a X1600XT
(as the physics card). Alternatively, you can hook up 4 monitors and do a
surround view.
On top of all this, the AM2XLI-eSATA2
supports eSATA2 ports. This allows you to hook up eSATA2 enclosures which allows
SATA HDD to be connected externally without compromising the speed in contrast
to the lower performing USB or 1394 interfaces.
The mainboard supports up to a max
capacity of 8GB of DDR2-800 modules. comes with 4 ports of Serial ATA II 3.0Gb/s,
RAID 0, 1, 0+1, JBOD and RAID 5, and "Hot Plug" functions, and 2 ATA 133 IDE
ports, 2 ports of eSATAII 3.0Gb/s (shared with 2 SATAII ports), support "Hot
Plug" function. 5.1 Channel with High Definition Audio, 10/100 Ethernet LAN is
supported. The board is also Windows Vista Hardware Ready ROHS compliant. There
is also a HDMI_SPDIF header and the board supports 7.1 HDA using ALC888 codec.
Specifications
CPU |
- Socket AM2 for AMD
Athlon™ 64FX / 64X2 / 64 and Sempron processors
- FSB 1000 MHz (2.0 GT/s)
- Supports Untied-Overclocking Technology
Chipset |
- ULi M1697 |
Hybrid
Booster |
- ASRock U-COP
Memory |
- 4 x DDRII DIMM slots
- Supports DDRII800/667/533
- Max. capacity: 8GB |
Slot |
- 3 x PCI slots
- 1 x PCI Express x 16 / x 8 slot
- 1 x PCI Express x 8 slot
- 2 x PCI Express x 1 slots
- Supports Dual Graphics XLI |
Graphics |
- n/a |
Audio |
- Realtek ALC888 7.1 channel CODEC with High
Definition Audio |
LAN |
- Realtek PHY RTL8201CL
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN |
Connector |
- 4 x Serial ATAII 3.0 Gb/s connectors, support
RAID (RAID 0, RAID 1, RAID 0+1, JBOD, and RAID 5), NCQ, AHCI and "Hot Plug"
functions
- 2 x eSATAII 3.0 Gb/s connectors (shared with 2 SATAII ports), support NCQ,
AHCI and "Hot Plug" functions
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x HDMI_SPDIF header
- CPU/Chassis FAN connectors
- 20 pin ATX power connector
- 4 pin 12V power connector
- SLI/XFire power connector
- CD in header
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports) |
Rear
Panel I/O |
ASRock 8CH_eSATAII I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x COM Port
- 2 x Ready-to-Use USB 2.0 Ports
- 2 x eSATAII Ports
- 1 x RJ-45 LAN Port
Front Speaker / Microphone |
BIOS
Feature |
- 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support |
Support
CD |
Version) |
Hardware
Monitor |
- CPU Temperature Sensing
- Motherboard Temperature Sensing
- CPU Overheat Shutdown to Protect CPU Life
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
Accessories |
- Floppy/ATA 133 cables
- 4 x SATA data cables (optional)
- 2 x SATA 1 to 1 power cables (optional)
- 1 x HDMI_SPDIF cable (optional)
- 1 x ASRock Graphics Bridge
- 1 x USB bracket |
Form
Factor |
- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4
cm |
OS |
- Microsoft® Windows®
2000/XP/XP 64-bit/Vista™ compliant |
Certifications |
- FCC, CE, WHQL |
