ASRock AM2V890-VSTA AM2 board (VIA K8T890CF) Review Intro 5/5
Bluetooth 15 June 2006
from
various
vendors
BIOS II
Memory clk maxmemclk can be set to operate in DDR2-400,533,667 or 800. For
overclocking, it is advisable to reduce the memory clk. |
DRAM Voltage can be set to 5 options, Auto, LOW, NORMAL, HIGH and ULTRA HIGH |
Ram timing adjustements. You can set the CAS Latency, trp, trcd, tras, Ma
timing, burst length etc from the above screen. |
HT link speed is commonly known as HT multiplier. Default is set to AUTO
which is 1GHz. Set it lower for higher CPU CLK so that HT falls within the
limits of the 1GHz limit. |
Hardware health monitoring. CPU Quiet Fan option is
available. |
