ASRock ALiveNF4G-DVI AM2 board (NF6100) Review Intro 5/5
Bluetooth 8 Aug 2006
 Pricing from
various
vendors
BIOS II
Ram timing adjustments, as usual, CAS Latency, tRAS, tRCD, tRP, tRRD, tRC, MA timing, burst length etc. DRAM voltage can be set to 4 different levels. If you intend to overclock your DIMMs, it may be good to set it to High or Ultra High just to ensure stability.
CPU NB link can be set to 800MHz or lower if you intend to o/c the board beyond the CPU freq of 233MHz so that Hypertransport is within 1GHz++.
