ASrock 939SLI-eSATA2 (ULi M1697) Intro 5/5
Bluetooth 8 Feb 2006
BIOS II
CPU_NB link speed can be set to the above selections. For o/c, it should be set lower. This is usually known as HT Multiplier on other boards. CPU NB LInk Width can be set to 8 or 16 Bits
Vdimm voltage can be set to Auto, Low, Normal High or Ultra High.
Low - 2.55V , Normal - 2.6 V ,
High - 2.7V , Ultra High - 2.8V
Default setting of Auto is 2.6V.
Chipset Core voltage can be set to Auto, Normal or High.
Chipset Voltage: Normal - 2.1V , High - 2.2V
