Gigabyte 3D Galaxy Liquid Cooling System GH-WIU01 Bluetooth 8 Aug 2005
of
7800GTX
Introduction
If you read our
Computex 2005 coverage, you would probably have seen this kit before. It was
unexpected that Gigabyte would venture into liquid cooling system. In the past,
I did come across various brands of liquid cooling system but never had a chance
to have a hands on. I find it too cumbersome to install and I am worried about
possible leaks that might kill my system.
Lately, we
received this package from Gigabyte without prior notice. It is the 3D Galaxy
Liquid Cooling system. Upon opening it, I find many different parts for assembly
to make it work. The package comes with a pure copper base, a ceramic bearing
pump which is attached to a reservoir. The reservoir is where you hold the
liquid coolant provided. It comes with
Low water-level (LWP) and over-temperature
protection (OTP).
Clips are also provided for clipping the UV tubing to the pump and radiator.
There is a holder that needed to be installed onto your casing for mounting the
radiator
Large, pure copper base employs unique water
road design
Long-life, quiet and powerful ceramic
bearing pump
protection (OTP) (Patent pending)
Clear blue LED tank for straightforward
coolant refilling
Large aluminum radiator with 4-parts water
road design
Special aluminum fan cover enhances thermal
dissipation
Radiator installs easily onto most PC
chassis
Multi-purpose Nano-scale GIGABYTE coolant
1/2 inch special UV tubing material allows
for extreme angling and flexing
Fully compliant with MOSFET thermal function
(Patent pending)
Optional thermal partner: Gigabyte chassis
3D AURORA (GZ-FSCA1-AN / GZ-FSCA1-SN)
