Gigabyte GA-8I955X Royal i955X Mainboard 8/8
Bluetooth 16 June 200
5
Benchmarks - Clibench 0.717
clibench is a suite of benchmarks, some are self developed other are slightly modified industry standard benchmarks to check up your computer. It shows nicely modifications in a computers setup and differences between different architectures.
ULi M1695 Reference Board
  Default (2.8GHz) Overclocked (3.45GHz)
Dhrystone 2.1 8253 10127
Whetstone 1927 1145
Eight queens problem 9772
9294859829
Matrix operations 391661 375920
Number crunch 310641 94968
Floating point 21657 26649
Memory throughput 1986618 4293967076
The disk performance seems pretty good with native command control.
See Conclusion >>>
