Foxconn 955X7AA i955X Mainboard Review 2/9
Bluetooth 11 July 200
5
Benchmarks
Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs at 200.0. The Gigabyte GA-8I955X Royal is running at 200.6MHz.
We used a pair of TwinX Corsair DDR2 RAM and runs it at default SPD of CAS 3, 8-3-3 and below are the memory benchmark scores obtained. Both boards are running DDR2-533 (CPU:RAM=200:266). Looks like both the scores are a bit lower which is probably due to the difference in FSB.
