EPoX EP-9NPA+ Ultra NF4 Mainboard Review 2/7
Bluetooth 5 Jan 2004
Benchmarks
Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs at 200.9MHz which is within the range of 200~201MHz. Although a few points might be insignificant, the results might differ quite a bit in the actual CPU speed.
The following readings are obtained using CPU-Z.
We used a pair of TwinX Corsair RAM and runs it at CAS 2, 11-2-2. Below are the scores obtained for ALU and FPU. We can see that they are almost similar because the memory controller is built-in the processor.
